my 259D
Hello, new Member here. I have a drive motor problem. I have a 2015 CAT 259D, 2 speed, tracked skid steer serial #FTL03539. I have a machine code: 70-3, Parking brake voltage above normal. The left drive motor locks up if I am stopped and try to make a turn left or right, forward or reverse from a stationary position. It will not move & bring the engine down to almost a stall. If I go back or forward straight for a couple feet then make my turn, it will work fine. I have also been going in a straight line & that motor just locks up & & just skids that track. Also, when I start to move forward or reverse from a stationary position it is like that motor has the brakes on and you have to throttle up the machine to break it loose & it breaks loose & jerks in the direction I am wanting to go. I seen a You Tube video of a guy that had a drive motor apart & the plate the piston faces ride on is cast & had a crack in it so every time a piston face contacted that crack, the edge of the piston would get caught in the crack and started to wear a hole in that plate making it easier & for a piston edge to get caught in that hole. It seems like a the brake on that drive motor to me. With the price of these drive motors to be rebuilt, I wish someone had an idea or maybe had had the same experience. Thanks in advance for any help with this issue.
