Inland1
I have a 259b3 with a/c but, now have no power to unit. Fuse in fuse box is good. Tested relays and all have same ohms about 91. The only place i seem to have disconnect in voltage is at the fan switch. I can jump the switch and get the fan to work but, no light on main on/off switch. Does that switch, back feed in to the main switch and, needs to be connected? All I can figure is i may have a bad fan switch but, not sure if that will shut down entire system or if there is another issue and the switch is just a side effect. Thanks for any help.
