Fairfieldcounty
I have a 2011 257B3, everything works when the dummy/jumper plug for the front window is plugged in. Once I plug in the connector for the door, nothing works as if its not plugged in ( no hydraulics, wiper etc) no broken wires behind door cover, everything seems to be intact. Any ideas on where to start would be appreciated, Fuses are good, not sure if theres a relay or not or which it would be. is there a safety switch that I can check, my 246C has one on the door but I don't see one on this machine. Serial number is B7H00466 if that helps. Thank you in advance.
