CAT 247b No Start Issue
Donzi
Saratoga Springs, NY
I've had a 2005 CAT 247b for a little over a year. It has 1050hrs and is in good shape overall. It was running fine, then parked for 2 weeks and won't start.
Turn the key and no lights come on, hour meter goes blank, no crank
Tried jumping with cables
Replaced battery with new AGM
Cleaned battery cables and checked for loose connections
Checked for blown fuses, haven't found any.
Replaced ignition and safety switch on bar in cab - no change
Have 12.5v between battery posts
Have 12.5v to starter, main breaker and positive jumper post near relays/main breaker with key off
Have 3-5v to starter, main breaker and positive jumper post with key on
Sometimes the dash lights will come on with the key and it will get 12.5v everywhere until I go to start it. Then the dash will go blank and the voltage will drop back to 3-5v when checked. The starter will only click once, no crank.
Any recommendations? I'm at a loss.
74inchShovel
Washington
Do you have 12.5 from battery hot to frame? Take apart all grounds and clean. A bad ground can pass the micro current that will allow a volt meter will read as 12.5 but when you try a much higher amperage it won’t go.
That would appear to be the root of the issue. Is the 3-5V is measured at the incoming or outgoing side of the main breaker.? Simply turning the key from off to on should not do that. I wonder if there is a relay sticking somewhere.?
Do you have the electrical schematic for it..? If not post the S/N and you can have a copy.
Donzi
Thanks for the suggestions. I removed, cleaned and reinstalled the main ground to the starter and the three ground straps I could find. I have 12.5v from the frame/block to positive terminal of battery when key is off. Now I only have 1v when the key is on.
I will get one new relay and try swapping it out with the existing ones to see if that fixes it. I got the same voltage on both sides of the main breaker (12.5v key on, 1v key off). I do have a schematic that CAT Service emailed me. I just don't know what to look for when I have the same voltage everywhere.
Donzi
Update. I replaced both battery cables and it started. Both old cables looked fine and didn't show any resistance issues with a multi meter. Thanks for the help guys.
