I did not get any help from this thread so I just moved forward on my own. I was able to get a manual ($20 for an online version) and followed the Electrical and Hydraulics for my Auxiliary Hydraulics lines on the machine. The jerking of the auxiliary lines was just the initial pressure of the hydraulic pump when the machine started up, not really the auxiliary hydraulics working at all when you pressed the button on the joystick.
The first place I check was the fuse box for the machine, in front of the seat behind the panel. There are 2 fuses for the Hydraulics and both were good but I replaced them anyway and I cleaned the remaining and reseated all of them.(No Change)
Second, I unbolted and lifted the cab. I disconnected and jumpered past the seat circuit. Using the schematics I determined the location of the solenoids for the auxilliary hydraulic. There are 2 solenoids located on top of what appears to be a hydraulic connections block, located on the left-hand side of my machine just underneath the cab. Here is where I discovered my problem. The front solenoid wires had apparently been taped to the solenoid and had become detached from the solenoid itself. I did start the machine and engaged the auxiliary hydraulics to insure I was getting power through the lines and I did get the right amperage before and when engaged. Instead of someone purchasing the proper connector and connecting it back correctly, they just taped it. I purchased the connector ($7), don't let them forget to sell you the pin holders for the connector(2 for $4), from caterpillar. I rewired the connector and reattached it back to the solenoid, after checking the voltage to the pins. I also checked the wiring on the other solenoid and cleaned it. I reattached the jumpered seat connector, cleaned up the area under the cab, and closed the cab and bolted it back down.
I did connect my auxiliary hydraulics to my auger and engaged them from the cab. Problem solved. Hope this helps the next person. It seems intimidating at first but ended up being pretty straight forward process.
Check Points:
Fuses
Solenoid Power at the Solenoid
Joystick Power when engaged at the Solenoid.
