cat 236 - i just rebuilt lift cylinders, but lift arms keeps leaking down
Discussion in 'Skid Steers' started by makesumwake, Dec 31, 2020.
  1. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    1,729
    North of there but east of here
    The thing with standard hydraulic cylinders is if the piston seals are gone, they will only drift out, not in.
  2. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,698
    Elsewhen
    Depends on the rest of the system and the load imposed. When they go into displacement mode, with only the area of the rod to hold the load, pressures can shoot up increasing the typically minor leakage in the valves, or in some cases opening the port reliefs.
  3. 92U 3406
    Jan 3, 2017
    1,729
    Definitely. I meant just a sole, isolated cylinder should not drift inwards.
    Jonas302 likes this.
  4. makesumwake
    makesumwake Member
    Dec 13, 2015
    12
    miami, fl
    I took apart the lift cylinders again to take measurements with calipers and bore gauge.
    piston rod shaft diameter = 40mm (39.96mm)
    piston head seal diameter = 60.55mm (largest diameter seal on the piston head)
    piston head wear rings = 59.90mm
    cylinder bore = 60mm + 1/1000inch
    there isn't much force required to pull the piston out of the bore.
    I can pull the piston out with one hand, and push it back into the cylinder with one hand (50lbs of force required maybe)
    These clearances are probably too loose, and is making the lift cylinder operate in displacement mode?
  5. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    6,570
    It doesn't seem like the seals are the problem in my opinion.
  6. heymccall
    heymccall Senior Member
    Feb 20, 2007
    3,349
    White Oak, Pa
    Was the boom lowering valve checked?
    Were the boom UP and Down relief cartridges swapped?
    mg2361 and Nige like this.
  7. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    4,045
    Oklahoma
    I'm lurkingo_O
    Nige and mg2361 like this.
  8. LEGO
    LEGO Active Member
    Feb 13, 2021
    30
    Diesel tech
    Texas
    This would work if the lift cylinders dropped without any weight on the bucket, and it seems its only dropping with a load. but yes it would work, I know cause I did this with a backhoe, but the lift cylinders where dropping without a load, turns out when capped the boom did not drop. spent more time troubleshooting and turns out the spool in the lift valve was damaged with a big deep scratch.
    I guess in this situation if the same was applied, but with a load on the bucket youll get a good test to verify if it is in fact the cylinders or not. I havent seen the machine but I dont think it is the cylinders. Its something else.
