CAT 226 KOBOTA SWAP
Scenicrusier
Kansas
Retired, but still got to make a living
I sure hope some folks out there will reply as I have great interest in this subject.
Mike
PEVO
Temple, Texas
Id search the net for suppliers that fab adapters to marry different engines to trannys etc. I see ppl repowering jeeps and other small 4x4s to reto fit v2203s into them all the time. I can speak from recent experience with a v2203 repower. But to be fair it replaced a tired v1702 in my bobcat 743. So with the exception of alot of trade outs from one long block to another (minus the intake, injectors, lift pump and injector pump) in dropped in. Oh the main mount on back of engine needed redrilling to mount to the 2203 from the 1702. this also holds the starter. The v2203(non turbo) is WAY more powerful than the 1702 (36hp-vs-51hp). Also you barely bump the starter and the 2203 fires right up. These kubotas are popping up everywhere from salvaged OTR reefer units. got mine for $2k. Im in the process of repainting my bobcat ...cat yellow hence the yellow engine in pic. Its now going to be a BOB...CAT. That should mind f**k some ppl :)
charles walton
Etowah Tennessee
I am going to try and make the swap soon, I hope that someone who's already done it will chime in and tell me how easy it will be. Cat would not even so much as try to find a used block for me, there's no telling how many they have sold for scrap that I could have used.
Tyler d4c
Salix Pa
Contact weavers compact tractor they will get you a block be much better off fixing to oem in my book anyway
charles walton
Etowah Tennessee
I checked with Weaver's and everywhere else that I could find and no one has a block or a used engine. I have found some 3024c for $6k+ but I don't know if they are a drop in or not, I am undecided on what to do with the machine at this point.
