I don't suppose anyone might know offhand how to switch a pilot 225 from Cat to Deere controls?
There are 8 pilot connections in the cab on either side of the seat at the bottom rear.....
All experienced input is most welcome.
Thank you - Lutjen.
That era 225 most likely doesn't have a diverter valve like the newer "300" series to switch back & forth. Your local Cat service department should be more than happy to fax you over a copy of the 4 lines you need to switch underneath the cab at the valve body to make the conversion. I obtained a copy recently for an older 307 and had to remove the panel underneath the operator's seat under the house, and switch 4 color-coded lines around. Very simple to do with the diagram, but if you don't have it and try to do it anyways, it could be a disaster.
An outfit I used to work for tried it thinking the "mechanic" could figure it out, and 3 days later they had to call Cat and suck it up. They had it so fouled up, the swing was the boom, the boom was the stick, etc., and all they had to do was call in the first place to get the diagram.
Call Cat with your serial # and they'll hook you right up.
I just went to work for a new outfit that has 5 excavators...all Cats with John Deere controls. I would switch the valve and run it normally, then the other guy would switch it to JD and run it for 15 minutes, than I'd get in and AWWW...:Banghead back out and switch again. I was doing this with no exaggeration 10 times a day till I finally said I can't take it anymore...12 other guys aren't going to change for ME...so I retrained my brain one day when I was working by myself so I wouldn't kill anybody.
Now I'm right at home again with the JD pattern, but I still say it's an un-natural act to run it that way. The boom on my right hand and curling the bucket at the same time with Cat pattern is a natural function to me. I was able to fine grade with Cat pattern easily because the stick was being worked with my left hand back then, but oh well... I still get in and have to think of the first "move" that first time in the morning, so I don't look like a moron.
Hope that helped, good luck.
