Look on top of the final case toward the front side of the sprocket , there will be a oblong plate with a hex drive on it and 2 bolts holding it down.Is there a way to roll the sprocket without having to start up the motor.
There's a trick I did not know about!Look on top of the final case toward the front side of the sprocket , there will be a oblong plate with a hex drive on it and 2 bolts holding it down.
Take the 2 bolts out and turn the plate 180 degrees and put the bolts back in ,this takes the gear train out of gear and the brake won't work.
Make sure you turn this plate back before you run machine.
Good Luck
Bob
do you have a 225 or a 235?Wasn’t able to locate the oblong plate on the final drive.
235do you have a 225 or a 235?
Bob
