Cat 2017 259d loses power and is sluggish
Cgray
Texas
Got the fuse block back together and still no power to the fuel priming pump
heymccall
Western Pennsylvania
I has to wonder, where are you grounding your multimeter when voltage testing?
However you have to rig it, the multimeter ground needs to be on the battery negative. If that then shows good voltage at the fuse panel, then R&R the ground strap at the back of the cab, making sure all contact surfaces are clean from corrosion.
Cgray
Texas
I’m touching the red pin at the priming pump and the black(ground) to the battery and no power.
Cgray
Texas
I’m not getting good voltage to the fuse block
heymccall
No argument over fuel pump not having power.
The grounding the meter to the battery negative was in regards to the low voltage at the fuse panel.
Cgray
Texas
11.76 v at the battery terminals, behind the cab on the fuse block studs, reading 11.5 when key is on, (ground is attached to the battery ground). Also the 3 studs below the fuse block reading 11.7 same as battery
Cgray
Texas
found the problem, the pin that plugs into the back of the fuse block to accept the fuse leg in the front, needed to be spread open to put more pressure on the fuse leg
Cgray
Texas
Yes, it’s new, it came with the new priming pump. It primes fine and filled the water separator as it should have
