Cat 143h transmission
  • 1
    Votes: 0 0.0%
  • 2
    Votes: 0 0.0%
  • Total voters
    0
GEORGIOS198217
Greece
My serial number is 1al00815. But caterpillar told me that the control valve is changed and that is from a newer model but is ok it can work . The coil is all the same?
I still have problem. I repair the trans control but still I don’t get all gears.now it can’t engage 1 f and 5 f and 1 and 4r. What can happen? I put all coil new. I am afraid that the wires are confused. Can someone give me the plan of the wires with colors to check?
if you are missing those particular gears the problem (electrical or mechanical I have no idea) is in #6 clutch.
I would guess that you have everything connected correctly because the transmission is behaving normally other than the 4 speeds that are not working - but all those 4 speeds are relsated to only 1 clutch.
Have you ever removed the suction screens to look for clutch debris.?
GEORGIOS198217
Greece
Yes it was clean
Mark250
victoria,Australia
heavy equipment technician
hi George
it is a bit confusing because solenoid numbers don't line up with clutch numbers I will try and explain
sol A = clutch 3
sol B = clutch 1
sol C = clutch 2
sol D = clutch 8
sol E = clutch 4
sol F = clutch 6
sol G = clutch 5
sol H = clutch 7
the wire colours in order for the first row will be from the top
green and white
yellow and white
blue and white
orange and white
for the second row the wire colours will be from the top
purple and white
white and white
brown and white
grey and white
As you can see you are correct and the tails are in order
GEORGIOS198217
Greece
hi George
sol A = clutch 3
sol B = clutch 1
sol C = clutch 2
sol D = clutch 8
sol E = clutch 4
sol F = clutch 6
sol G = clutch 5
sol H = clutch 7
green and white
yellow and white
blue and white
orange and white
purple and white
white and white
brown and white
grey and white
Thanks mark i will try right now
Mark250
victoria,Australia
number 4 clutch is common to the lost gears
you can move solenoids around to see if the problem moves as a first move. but normally if the wire or solenoid is open you will not get gears past that point
if you have testing equipment check the pressure at the clutch test point
when you removed the control valve did you fit the correct CAT o rings and torque the retaining bolts to 30nm or 22 lb these aluminium valve bodies can do strange things if not treated correctly
GEORGIOS198217
Greece
I do that but nothing. The valve was rebuilt by caterpillar.I think that i have no volt at E coil
Mark250
victoria,Australia
have you checked for continuity of the wires between the ECM and the solenoid (I thought you said you did in an earlier post)
As I said in an earlier post you need to have good wire continuity and a good coil before the ECM will deliver 24 V to the coil
if there is an open circuit coil all you will measure is usually about 5v or zero if the wire is broken
So leave coil connected and back probe the coil connector to check for voltage if no voltage at coil connect a good coil directly to the ECM under the cab and check there
