Cat 140g 3306pc smoking like crazy
Discussion in 'Motor Graders' started by M-a2022, Aug 16, 2022.
  1. M-a2022
    M-a2022 New Member
    Aug 15, 2022
    4
    Kansas
    Hi just put in a reman long block into machine. Starts rough and smokes like crazy, low and high idle. Double and triple checked injection pump timing, valve lash, injectors are good.I have a new mechanical gauge attached to the hose off the side of injection pump, When using the hand primer pump (which don’t leak when using) I get some pressure 15psi it drops to 0 in a matter of two mins, I’m confused when I look up a check valve it shows me the hand pump, also when running fuel pressure around 26psi you can use the hand pump and still smokes, also when running started cracking injection lines and still smoked a lot and ran rougher. I’m at a lost now what to check?
  2. heymccall
    heymccall Senior Member
    Feb 19, 2007
    4,116
    White Oak, Pa
    Black smoke?
  3. M-a2022
    M-a2022 New Member
    Aug 15, 2022
    4
    Kansas
    Yes black/blue, I’m going to put a boost gauge on and see if turbo is working.
  4. heymccall
    Feb 19, 2007
    4,116
    White Oak, Pa
    When I had 3306's in my 330 Cats, I had to replace the aneroid (air fuel control) diaphragm on the injection pump(s). The diaphragm would tear at higher hours. IIRC, though, they didn't smoke at idle.
    Is your aneroid even hooked up (small pipe/ tubing from intake manifold)?
    Does it smoke with turbo air inlet disconnected (don't even think about putting anything near an open turbo inlet, rag, tools hand, etc...)? Use due diligence if you try that.
    Could someone have left a rag (or whatever you covered the ducting with) in the intake tubing somewhere between the air filter, charge air cooler, or turbo?
    DB2 and John C. like this.
  5. John C.
    John C. Senior Member
    Jun 11, 2007
    12,131
    Have you checked the fuel lines from the tank to the primer pump? Did you check the O ring seal in the fuel strainer housing.
    Sometimes a precup engine will do that till the rings seat in. If you are sure everything is good, you need to get a load on the engine to get those firing temps up.
    DB2 likes this.
  6. Bluox
    Bluox Senior Member
    Jun 19, 2010
    1,832
    WA state
    Are you timing off the cylinder towards the radiator or the flywheel housing?
    Bad Bob
    bccat, John C. and DB2 like this.
  7. Coaldust
    Coaldust Senior Member
    May 9, 2011
    2,208
    North of the 60
    Where did the long block come from?
    John C. likes this.
  8. M-a2022
    M-a2022 New Member
    Aug 15, 2022
    4
    Kansas
    Timing hole thru flywheel pin it and check #1(towards the front cover housing) both rocker arms loose then the side plate on injection pump the 3/8 bolt taken out and 1/4 pin slides all the way in.
  9. Bluox
    Bluox Senior Member
    Jun 19, 2010
    1,832
    WA state
    Thats #1 towards the back of the cab is the correct way, its surprising how many gets the engine turned around like setting valves.
    Is this the same pump that came off your old motor?
    Bad Bob
  10. M-a2022
    M-a2022 New Member
    Aug 15, 2022
    4
    Kansas
    Yes same pump from old motor, old motor had 150hrs on a rebuild didn’t smoke or lack power but had an overheating issue, I found bad head gasket tore apart and found two cracked head bolt holes from another mechanic that rebuilt before coming to me, I put on a new primer pump
    This morning and a boost gauge gotten alot better with smoke but still has some about half of what it was, also found #6 injection line leAking at the injector, got new one on its way hopefully after that it will run correctly
  11. Dave Neubert
    Dave Neubert Senior Member
    Jul 18, 2018
    1,212
    Monroe NC
    Are you using Cat nozzels or aftermarket
    Coaldust likes this.
