Onfoot
As I continue to learn the ropes, I am wanting to test the glow plugs on my 1968 12F. (S/N 58H498) The current p/n is DS-3T-9562 (original p/n 3S-9624). Can anyone tell me what should be the ohms? Thanks!
An ohm meter works just fine. Just pull the connecting wire off before testing a plug. The failure mode is a short to ground or no continuity at all. Those plugs use about 7 amps each. If you have a working amp meter on the panel, it should go all the way to the left when you turn the switch to heat. That should be no less than 35 amps.
