1mancompany
Hey,
I started my case the other day and was letting it warm up. I heard a loud noise that didn't sound good, sort of clunking. I ran to it and shut it off. Checked around could not find anything wrong. I cranked it back up (no noise) and put it in forward and it surged a couple of times. I put it in reverse and the same happened now nothing. On top of the trans is the hyd pump, the charge pump with filter and the cooling pump. I pulled the pumps and tried to look at these gears as I tuned the engine over. The best I can tell, the gear that turns these pumps is not turning. Went to casece parts diagram and cannot get a good pic of this gear and what turns it or how it works. I pulled the plate to look at the fly wheel, it turns with out obstuction and turns freely with engine running. I pulled the screen on the side of the trans tank and it had very little fine bright metal shavings and some gasget maker on it but was pretty clear. All total the metal shavings would have not been more than a finger nail. I have not checked the other screen on the back as I did not know there was one there. The trans magnetic plug did not have chunks of steel on it. Is there somthing that stops this gear from turning, is there a pump swome where I am missing or does anyone know what could be wrong. I really need to put it to work.
oh the loader had sat for a couple of months and squirles had built nest and chewed wires.
I know there are some of yall who know a lot more about machanicing on these things than I do. So I am willing to listen and start the trouble shooting all over to get to the problem. I called a local shop and and the best they could tell me is they would have to take it apart and it would cost between $2500 and $5000. The last time I did that with my skid steer they told me oh it will be a couple hundred bucks, When I went to pick it up it was $900 and and the problem still wasnt fixed. I told them about it and they said well we did all we know to do. When I asked about my $900, they told me well we had alot of time in it and thats just the way it is if I want my skidsteer back. I wound up trouble shooting that one myself and after $400 and a new Control display panel it was fixed. Had a similar situation with the two close by John Deere shops. So as you can see im not big on just droppin it off. I hope to be able to fix it myself or at least tell them what I want done so I really know what Im in for.
Hope yall can help.
Hope yall can help.
