Hi guys,
Today we had our 2013 Case TV380 skid steer randomly stop working on a job. The machine suddenly started moving backwards on its own, and I counteracted by pushing the joysticks forward. As soon as I did that, the machine seemed to error out and the STOP light lit up, as well as the hydraulic override light flashing.
If I raise the lap bar and put it back down, then push the operate button again, the machine does the same thing and tries to go backwards on its own for a split second, then errors out.
We had two codes coming up on the display:
4752
5512
EDIT: I ended up finding the codes online:
4752: Ground drive: Command plausibility check
5512: Bucket rollback/dump: Sensor implausible state
Does anyone by chance work at a dealer or has access to the service manual to tell me what these codes mean?
The lap bar and seat sensor seem to function fine, and the appropriate lights go on when you sit in the seat, and when you put the bar down.
The machine had this problem a while ago (years), but it went away after restarting the machine. This is the first time it's happened in a long time.
Anyone had this happen to them before? Any insight other than checking the wiring and sensors on the joysticks? I guess I'll start there...
Thanks,
Elliott
4752
5512
Thanks,
Elliott
