rackmaster
I just purchased a 2011 case tv380 , and want to service the machine. I get conflicting advise on what hyd fluild to use.
recommendations are
1- just use a 10-30 motor oil, or rotella 15-40
2- do above but use aditive to prevent foaming
3- use execuvator fluid due to heat buildup, which this fluid is more resistant.
the manual calls for a 10-30 fluid, but no additive, so I interept that to be just a straight good grade 10-30 auto oil, is that correct or am I missing something??
would you add the anti foam agent?
Ive read several posts, also. even the case site does not have the TV380 listed under the tool box section on picking proper fluids. I did notice the older units suggested additive, but the later models shown did not.
Just looking for good experienced advise.
Tks,
recommendations are
Tks,
