andersoncol_2
I picked up a 2008 Case 420CT (series 3)and while hooking up to my attachments, i found the hydraulic couplers are extremely difficult to hook up. Obviously there is pressure on them from the machine and the possibly the attachment. I know that bobcats have a manifold with a pressure release. Is there a way to relieve the pressure on this one? I called the Case dealer and they said to pull the fuel pump fuse and work the hydraulics while holding the start button. I don't think this is the option for me. There should be a better way. I couldn't even find a fuse or relay that had fuel pump beside it. I don't really want to have to crack the lines loose and leak oil all over the place either. Anybody out there have a better procedure or a fix for the issue?
