Case Maxi-Sneaker
Discussion in 'Other Compact Equipment' started by GMC Driver, Mar 14, 2009.
  1. GMC Driver
    GMC Driver Member
    Aug 19, 2006
    8
    Wainfleet, Ontario
    We're a small landscape contractor who has been slowly building an irrigation division. Last year we installed approximately 50 systems in the course of the season, and early indications are that this volume will continue for the upcoming season.
    We have used several different vibratory plows for the purpose of installation of the pipe. These have all been walk behind units, and while they work well in some applications, we have found they don't suit our needs. Alot of the work we are doing is in new home construction, and as such, we are installing the systems prior to sod.
    Where I'm looking for input is if anyone else has experience with vibratory plows, or more specifically Case Maxi-Sneaker C units, as they seem to be better suited to our needs. I'd be interested in other's recomendations.
    These are now sold under the Astec banner, as the Maxi-Sneaker D, but are quite pricey new. There are several used "C" units out there, but in quite a price range.
    In addition, if anyone has a lead on the sale of a suitable unit, or a reputable dealer, please let me know!
  2. backhoe1
    backhoe1 Well-Known Member
    Aug 24, 2007
    92
    South Dakota
    I spent lots of years running ditch witch 255sx, rented maxi sneakers for big jobs, hated sitting sideways on a machine when I should have been walking.
    Every time I returned it the salesman would ask how I liked it and I would say "Well, it ain't no ditch witch". I personally would prefer an orange 410.
  3. shaper
    shaper Charter Member
    Dec 16, 2003
    35
    Golf Construction & Irrigation
    South Portland,ME
    GMC DRIVER
    I used to operate a Maxi-Sneaker for plowing pipe and wire on Golf Course Irrigation jobs. We pulled mostly 2" PVC at a depth of 14-18". In hard compact soils it was tough to get those depths, lots of times on new construction jobs the top 3-4" of soil was loose and the machine would loose traction. For home systems you won't need that much depth, so it shouldn't be a problem
    For home systems or Athletic fields this machine was ideal. The turf guards do a real nice job of keeping the heaving to a minimum. Hit it with a roller after and you would never know you plowed
    Not sure what the options are now, but the sneaker I ran had the 4 sets of duals. I have seen some with just singles. Definately look for one with the duals.
  4. gggraham
    gggraham Senior Member
    Feb 13, 2009
    316
    Licensed Heavy Duty Equipment Mechanic
    Maxi C
    Our dealership sold a lot of Maxi's over the years until Astec took them over.. They were very simple to maintain and repair. The shaker boxes are so easy to disassemble and repair and tons of them around. Definately get duals if you can they are more stable on a hill. Plus it's easy to remove the duals for a tight area like a residential yard. Kubota engine in the C and not a problem with them at all. Basically the C has not changed much except for the engine and axles since the first Maxi. I have worked on Burkeen and Ditch Witch. Both seem to be fairly reliable as well but I found the Maxi's easier to work on and a lower cost for repairs.
    If you buy used the first thing I would check are the rubber mounts on the shaker. The shafts and rubbers are "keyed" ( see attached picture) make sure they are in line not sheared. These can be somewhat expensive to replace if you need all 8, and if they are sheared it will not shake properly. Also check for cracks on the shaker tower and frame. Both these symptoms many times are caused by abuse or an inexperienced operator.
    My 2 cents worth of advise. :)
    Hammer103 likes this.
  5. GMC Driver
    GMC Driver Member
    Aug 19, 2006
    8
    Wainfleet, Ontario
    Thanks for your input guys.
    I found a C with 6oo odd hours on it, but was in NC. I've got transport arranged to get it to PA next month by a really kind gentleman from NC who I'm going to owe a huge thankyou. From his description of the machine we did rather well, so if it is going to require a little PM to get it up to par, that would be fine.
    Again. your input is appreciated. Once I have possesion of the unit, I may post more details. A bit of a risk site unseen, but I saw it as a can't miss opportunity.
  6. Leon Phelps
    Leon Phelps Well-Known Member
    Oct 6, 2010
    86
    PA
    sorry to drum up an old post, but I have a problem with my mini-sneaker. the frame has cracked on the back. Basically part #12 on the photo. I am pretty good fabricating parts. Anyone have success welding the sheared off frame then reinforcing the parts?
    Also, I see two top bolts that keep the piece on then two lower bolts. If I unbolt, will the piece just drop off?
    Thanks for any help.
  7. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,136
    Service Manager
    Knoxville TN
    I've seen a couple of sneaker frames cracked and had to repair/reinforce them. Taking the unit off is not a piece of cake, you have to pull the side links off of both sides as they fit onto keyed shafts, that's when you may find the key stock on shafts worn and the keyway in side links worn as well. Lastly, you have to disconnect the hyd lift cylinder from the rear frame to free it up.
  8. Leon Phelps
    Oct 6, 2010
    86
    PA
    guess I should start soaking everything with penetrating oil now.
    thanks. I did see a couple for sale that were already repaired.
  9. remmsouth
    remmsouth New Member
    Oct 25, 2012
    1
    georgia
    I am looking for the shaker box only to a CASE MAXI SNEAKER SERIES C P40 machine, have checked with distributors for new boxes but they are $2000.00 can anyone help with a used one. Or know of any grave yards for these machines where I might could purchase a used one
  10. Hammer103
    Hammer103 New Member
    Feb 10, 2017
    2
    Utility Contractor
    pennsylvania
  11. Hammer103
    Feb 10, 2017
    2
    Utility Contractor
    pennsylvania
    I just bought a 2004 Maxi C with 1500 hrs on it and am having the same issues that you describe with the shaker box bushings and key ways worn out. I owned 3 Maxi C machines and never had the problems I am seeing with this one. The machine is shaking it
    self apart like its having siezures!
  12. jcmarleau
    jcmarleau Member
    Oct 26, 2008
    11
    L'Orignal, Ontario Canada
    If ever needed i do have a original service manual for sale for the maxi sneaker model for sale. jc marleau
