My father has a 2008 case cx31b. One track side has very little power. It has been this way since he bought it last year(never let him buy something alone). Anyway, we had a local guy check it out. I believe he did a pressure check and everything was good and everything appeared fine visually. He also checked and adjusted track tension. The drive that we are having problems with appeared to be new or close to it. He took a job with the state and didn't have much time to work on his own, so he returned the machine to us at no charge. Everything else works great. Motor runs perfect, digs great, other track has plenty of power.
Anyway, now we're going to try to tackle this ourselves before sending it to the dealer($$$). I'm not familiar with this equipment so we're going to learn as we go. I'd like to start the troubleshooting over from scratch.
The fact that the final drive has been replaced leads me believe the problem is elsewhere. Is there any way to rule out the final drive as the issue?
Are there any filters in the drive system that could be clogged?
Is there any diagnostics or troubleshooting lists i could follow to find the root cause of the issue without just jumping around?
I appreciate any guidance you can give me.
