Coy Lancaster
Hey Guys I've got a question on a Case CX210. The problem is that the right track is slower that the left track. It started out as the track would not go in reverse, but now the track is slow in both directions. The P1 pump pressure is good when arm and swing are operated but the pressure drops when the travel pedal is activated. I capped the travel lines at the final drive and the pressure did not come up, then I capped the lines above the swivel and the pressure was the same. Long story short I removed the foot travel valve and checked the spools and plungers and replaced seals. I reinstalled the foot valve and the machine worked fine for about a day. P1 pump pressure will not come up when travel valve is activated even when arm is activated at the same time. The final drive and motor have been replaced also the main hydraulic pump. Any thoughts or ideas would be appreciated.
