Thanks for your replies. So I replaced both sensors for the uppers functions and travel. That cleared the code but the stall condition still exists. When any function is activated, (travel, anything, if you go hard it will stall engine at 3600-3700 psi for both P1 and P2 pumps. Definitely not fuel related as mentioned multiple times fuel pressure at the VP44 pump is 13-14psi and the throttle is instant when you let off control before engine stalls. So now no codes in diagnostics, all filters on machine have been changed. Desperate for any help.
