Case 9180 Steiger hinge bushing
Discussion in 'Agricultural Equipment' started by southernman13, Jul 17, 2021.
  1. southernman13
    southernman13 Senior Member
    May 13, 2008
    858
    Retired
    Florida,Ga,Tn
    We got one. Haven’t decided if we’re gonna keep it. It needs the lower hinge bushing replaced. This one is broken/worn. It looks like this is basically a 3 part system. I just can’t figure out if the tractor needs to be split into 3 parts to get to this lower hinge pivot point. It’s right above the draw bar. Trying to upload a pic but not having any luck this morning
  2. southernman13
    May 13, 2008
    858
    Retired
    Florida,Ga,Tn
    This is where the bushing is located
  3. jonno634
    jonno634 Well-Known Member
    Dec 20, 2018
    119
    Farmer
    Garfield, WA
    We split our 9170 to do them.
  4. southernman13
    May 13, 2008
    858
    Retired
    Florida,Ga,Tn
    Cool deal. I just cleaned ours up and Ben staring at it. I need to replace the hinge bearing. It’s between the middle piece and the fuel tank. I’m not sure I can separate the middle piece from the fuel tank side without breaking it into 3 pieces. It looks also like I can’t get it apart without pulling the complete drive shaft out. I’ll take any advise u can give. I’m ready to do something if it’s wrong lol. Thanks
  5. southernman13
    May 13, 2008
    858
    Retired
    Florida,Ga,Tn
    I just at the 9170. Looks identical to mine. Please advise on best way to proceed if you can. Thanks again
  6. jonno634
    Dec 20, 2018
    119
    Farmer
    Garfield, WA
    Replied and discussed via email, and phone.
    for others, something to note: the two lower pivot pins with threads are different lengths (so, they are not interchangeable).
    If changing, I recommend changing all of the bearings, as you won’t want to pull it apart to do it again. Also, crossing hyd hoses on one steering cylinder, allows you to use the steering wheel to push the tractor apart, and pull it back together… fittings are different sizes, so had to make adapter hose.
