I have a case 90xt with about 1500 hours on it. I started having problems with this when it started getting cold. I could get in start it up the seat switch would light up but the bar switch would not seems like the longer you have it running it lights up then on the left instrument panel the green light appears and you're off and running fine. So now I got in it started right up as always, seat and lap bar light came on looked at the left panel it was green it moved then got out got back in I left it running and I have no seat or lap bar light on the right side but the left side light is on but won't move. The sticks will move back and forth the back up alarm even comes on but I can't move and I can't raise my forks. I thought it could be seat or lap bar switch, but going out at the same time? So I checked the bar switch it (did an ohms test) it had some resistance on it. I didn't check seat switch yet. I still don't have any green light on the right side instrument panel and still have a green light on the left instrument panel telling me I'm good to go. Could there be a bad connection in the right instrument panel? Also if I just touch the key while it is running the battery light will come on then if I jiggle the key the light will go off. Any info would be good thank you in advance.
