Coy Lancaster
If you check pressure with track blocked and pressure is low and then cap off lines at motor first and retest. You will find out if problem works s in motor. If pressure is same the cap lines above swivel which will eleminate the swivel, if pressure is at main relief then you know swivel for is the problem if not then you need to look else where. I did have a machine wit a bad pump regulator once that acted just like this.
