case 850b rpm governor
mtnman
booneville,ky
can anyone tell methe max rpm on 850b?the screw come off that stops my throttle.i was thinking 1500-1700 range id like to verify it,hate to blow engine,also need a diagram of angle cylinders plumbing,im thinking that a single hose goes at bottom from one to other then top of each has the hoses attatched from dozer.ill thank uall ahead of time id b lost without this site.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
The RPM is usually stamped in the name plate on the inj. pump.
If its a RoosaMaster or CAV it'll be on the side..
if its a Bosch IN-LINE it'll be on the back side of the governor.
If its a Bosch ROTORY it'll be on the side.
alrman
QLD Australia
The max revs on a 850B with no load would be 2200 rpm.
Have you sorted the hose issue? Removed the hoses & not marked them?
mtnman
booneville,ky
thanks.yeah on my hoses i thought i knowed how they went back.had welding done on blade,didnt mark hoses.im sure about all of them execpt my angle cylinders.im thinking 1 hose connects between the 2 on bottom then the ones from dozer goes to tops.thats wrong i meant vise versa.coming from dozer to bottom.
