So last weekend I put about 12 hours on this thing making a road on the property. A good part of it rock (fractured shale). Super impressed with the ability, anything else would have taken considerably longer. Going to change the oil but decided to go through everything and grease what i could find zerks on. Strange that every pivot didn't have one. Removed one pin and drilled it length wise for a zerk which was easier than I thought but when I tried to drill it on the outside, nothing doing. Obviously hardened. What would a guy do here? Also had a couple that would not take grease. Removed the zerks and they were not plugged. Any thoughts? Figuring on removing the pins, cleaning the holes and checking for a blockage unless someone has an easier trick. Couldn't find one majorly important one on the main lower pin for the hoe mast. Attached is a picture, I'm thinking it's behind the plate that's bolted there? Thanks!
Dan
