Thanks for the info guys. I haven't had much time to work on this because I'm working 12 hour days. I did drain the chain case and got 18 gallons of oil out of it! Yes, 18 gallons! I have the side cover removed and now I see that the park pin is hydraulic operated. So my leak is either coming from the park pin actuator or the hydraulic motor. The machine operated perfect before I started taking in apart so I'm starting to think the park cylinder might be the cause. The only problem I had was that the machine was go into park after I used it for a while and I figured it was from the hydraulic fluid being low. Like I said, been busy with work and have only had a few hours a day to work on it and Monday I leave for a week on christmas vacation. Hopefully this weekend I'll get some time to take the drive chains off and pull the sprocket off the hydraulic motor, then start the machine and look for the leak. I want to see the motor or park cylinder leaking before I remove either. Someone also has been in there before because the chain cover and where the park cylinder mounts to the chassis has blue silicone on it. Hardline, Thanks for the heads up on keeping the hydraulic fittings clean. I'm very awear that you don't want to get dirt in to the hydraulic system. The simplist way I can see to get the hydraulic motor out is to remove the floor boards and the vertical cover just under the front of the seat. I took this cover off and the motors are right there. Once again, thanks guys and I'll keep you posted.
Vince
