soapstoneguy
Hey everyone,
I have a case 680e backhoe, not exactly sure the year but i'm guessing somewhere in the mid to late 70s since the manual says it was printed in 75.. It has recently started having hydraulic problems. i thought it was the pump because the bucket wouldn't raise, steering went out and none of the hydraulic controls were working. it made a grinding noise when it first started up and when i would give it gas and that is when everything stopped working. if i kept giving it gas then the grinding noise would go away BUT still no hydraulic controls were working. the grinding sounded like it was coming from inside the cab. i pulled the pump off, had it rebuilt, put it back on and still have the same problem. HOWEVER, now that the pump is rebuilt and back on the 'feeder' hose (thats what i call it, the one that goes directly from the hdraulic tank to the pump) gets starts collapsing when i start the machine up. when i turn the machine off it goes back to normal...i cracked the two hoses that run off the pump to see if i was even getting any hydraulic fluid and i am because they spit out some fluid.
any ideas? i'm thinking it is the control panel?? if that is the real name for it, that the hydraulic fluid gets pumped to after it reaches the pump?? not a lot of experience with this problem so any info would be great!
Thanks guys.
Thanks guys.
