JVRatc2
Just bought a Case 650K series 3 with some electrical issues that I am trying to sort through. 1st thing I was trying to accomplish was getting the machine to start from the key. Ignition works because I can start the machine by jumping power to the solenoid, hydraulic funtions work.
List of things that are wrong: I don't get power to the white wire going to the solenoid, machine will not travel, drive speed indicator pointing straight down(joy stick was replaced), display shows "N" when the key is first turned on but quickly goes away, menu buttons do not work so I can't see codes, light switch and lights work, trans fault light comes on after a few seconds of the key being turned on plus a number of other things.
I'm trying right now just to get the thing to start from the key if possible. 4 relays in the left fuse panel click when ignition is turned on and also when turning the key to start.
Just want to get the conversation started and hopefully a little guidance as I try to sort through all of this stuff.
Machine has 950 hours. Serial # CAL012256
