JBlackwell
It is a 1991 model straight 650, not a 650G or 650H. Has 6-way blade, ripper, OROPS, 4BT 80hp Cummins turbo, sprockets, idlers, rails all in good shape. Growlers are good and 20" wide. The ripper has 5 pockets and have 3 teeth for it. Just pulled belly pans to clean all debris out and also put in new motor mounts and upper radiator hose (have lower but not installed), 10hrs. on oil change. Recently repacked lift cylinders on blade w/ new hydraulic lines (old ones were weather cracked). It has new fuel pump because I found a new one really cheap so I was doing a little preventative maintenance. It has a PTO in the back if one wanted to pull the ripper off and mount a winch.
The things that it may need; 2 guages don't work, cutting edges on corner of blade could stand to be replaced if cutting into hard soil, has very small hydraulic leak on one of the hoses on the blade. I have not found which one yet. I believe thats it.
Machine weighs about 17,000#. I can haul it on my gooseneck trailer pulling it with my 3/4 ton Dodge cummins.
I am asking $21,000. I have a brushrake that could go with it also.
Justin
903-720-2979
Justin
903-720-2979
