FastYZFR1
Hi I have had an old 621 for a few years now and put about 500 hours on it. The transmission has been behaving very good with the exception of transmission overheating according to the gauge after a few hours of working it hard digging in dirt. I am near Chicago and use the loader to push a 16ft snow box. Today I went to use it and it moved a few hundred feet then slowed to a stop. The day before it was working great moving snow for 4 hours or more.
I put the 15w40 motor oil in the trans when I bought it, was getting ready to change it to HD30 the overnight temp was in the 1-3 degree range overnight. I started it and let it warm up about 15 min and went to move it and it moved a bit then stopped. Letting it sit and idle for an hour or so it moved another few hundred ft then stopped again. I changed the filter (oil looked fine) still didn't want to move. I let it run for another 4 hours now it would move but after just driving it 1/8 of a mile in 1-3rd gears different directions the gauge would indicate trans overheating but it didn't seem to get too sluggish Though I didn't run it with the trans overheated I didn't want to do any more damage to it, any ideas?
it's a 621C with 8200 hours on it, I tried to do the trans calibrate and it seems to only get through doing 1st then stops in 2nd gear, I was able to get it to go a lil further if I increased engine RPM but it still wouldn't complete the process. I am thinking either it lost the converter or blew a seal in a clutch pack or maybe even an issue with the charge pump.
Thanks for any help
James
I
Thanks for any help
James
I
