Looking for some help boss bought this machine sight unseen
biggest problem with it is the hydraulics both steering and bucket functions are weak and pump sounds like it's cavitating
Replaced pump same thing happens
Replaced main relief valve same thing
Can't raise bucket empty without giving throttle and still sounds like pump is cavitating same with steering have to be moving to make full turn and you can hear the loud grinding like the pump cavitating
Can't lift a full bucket of material unless you put it to the floor and sometimes deadheading the steering helps it
Put a gauge on the pump test ports can't even get 1000psi
What next to check on this thing it sounds like it's going over relief as soon as you hit any function but I don't know what would cause that any help is appreciated
