rondejack
I was traveling over road 5mph and trans went into neutral, the computer display started flashing C P the F was flashing also.I noticed the volt guage was also pulsing down 1/4 inch at same rate the display was flashing .I pressed the M button for few seconds and just went to 8 8 ,and when released went right back to the original display . unhooked battery for 10 minutes ,didn't change a thing .I had changed the speed sensor last year through info from this forum and has worked fine until yesterday .wondering if a relay or short could be the problem ,called CASE they have no code for C P that they know of .. thanks rondejack
