Case 580M Over revving
Discussion in 'Tractor/Loader/Backhoes' started by Zardiw, Jun 11, 2019.
  1. Zardiw
    Zardiw Member
    Jun 11, 2019
    6
    Palm Springs
    Hey Guys......
    When I start it, it immediately over revs....so I shut it down immediately.
    Could the throttle be stuck?
    It had been sitting for a couple of months.....I'm in the desert and recently it's over 100 degrees.
    Anyway, yesterday I tried to start it and it started up but then died.
    It would keep running if I gave it a lot of throttle, but if I let off it would die......and had a hard time starting also.
    I decided to let her rest for awhile, and I went out today and when she started she went immediately into over rev mode.....
    Any thoughts?
    PS. This is a 2006 580M Backhoe
    Thank you.........z
  2. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,753
    Master Inj.Pump rebuilder
    Sunny South Carolina
    Which inj. pump?? Bosch Ve or Cav DPA..??
    Its rare that a VE runs away unless its just loaded w/ water & rust..
    The DPA WILL run up on the gov. w/ a stuck metering valve & are VERY PRONE to rust/water.
  3. Zardiw
    Zardiw Member
    Jun 11, 2019
    6
    Palm Springs
    Thank you for the info!
    Posted a pic below........... Checked the throttle linkage and it seems to be working.
    SO.....take it apart?..........bang on it?
    Btw.....your join date is my bdy.......fwtfw......lol
    z
  4. Zardiw
    Zardiw Member
    Jun 11, 2019
    6
    Palm Springs
  5. Zardiw
    Zardiw Member
    Jun 11, 2019
    6
    Palm Springs
    I bought it from a guy in Pennsylvania.......it has a LOT of rust...replaced all the filters, fluids, etc......the exhaust manifold is really rusted......haven't got the chance to dig into replacing it......guess I'll be replacing/rebuilding an injector pump instead.....lots of fun looks like......lol.......unless there's an easier way to fix it........
    She was running fine earlier....for several months.....maybe cause I let her sit too long w/o starting her up?
    PS. She's in the desert now, so rust isn't a problem for her anymore......
  6. joe--h
    joe--h Well-Known Member
    Jul 22, 2009
    192
    Utah
    Free advice, send pump to thepumpguysc.
    He does a good job & he'll even take a bad check for payment.
    Joe H
    chas357 and Vetech63 like this.
  7. thepumpguysc
    Mar 18, 2010
    4,753
    That's a Bosch VE pump.. so RUST is at the top of the list..
    OR that bulbous lookin thing on the side.. the cold start devise.. has exploded internally.. {very common}
    Its not advisable to take it apart.. once u start loosing parts, some can only be replaced as "assemblies"..
    & can be costly..
    U could remove the solenoid on the CSD & see if u see metal around the stem of the sol. or in the housing.
    & u could remove the return connector & see if its rusted or has rust on the threads.. & btw, it should rattle if u shake it.. theres a piston inside of it..
    SO, metal on the CSD sol or hsg.. & rust on the outlet bolt threads..
  8. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,583
    Oklahoma
    Ok....
    That was hilarious!!!
    mg2361, Tinkerer and Wytruckwrench like this.
  9. Zardiw
    Zardiw Member
    Jun 11, 2019
    6
    Palm Springs
    OK......Thank you! ....I'll check those things.........What do you recommend? They got some on EBay for not that much money.....fwiw........
    z
  10. alrman
    alrman Senior Member
    Jun 20, 2009
    2,405
    QLD Australia
    There is a small seal that could be leaking fuel into the diaphragm on the top of that pump, sending fuel to the intake uncontrollably.
    It will require specialised repair skills...... hopefully by a fuel technician with a calm aura :rolleyes:
    Tinkerer likes this.
  11. thepumpguysc
    Mar 18, 2010
    4,753
    Z.. what are u talking about, "not that much money"?? I'm seeing 2000.00.!!??
  12. joe--h
    Jul 22, 2009
    192
    Utah
    Send it to the pump guy.................
    Joe H
  13. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    3,561
    On A Riverbank in IL. USA
    Do yourself a favor and PM thepumpguy for rebuild appt. !
  14. Zardiw
    Zardiw Member
    Jun 11, 2019
    6
    Palm Springs
    Alrman.....Inside that square thing on top with 4 bolts, right.....one of em is a security allen, but I think I have one of those.....
    There's also something on the bottom right that could be removed........and the big hose that goes into the left side.
    Thinking that anything I can check w/o pulling it (which seems to be a bear...Kodiak type....lol)...is preferable.
    I just did a quick check on EBay and saw prices of $500 or so.......but probably the wrong kind.
    Just want to thank you guys for the ideas..........and if it needs a rebuild, I can go with the pump guy.......pretty sure I have a few bad checks lying around........lol....
    Bottom Line is it needs to be done, and needs some money thrown at it.......working on that part.
    Fwiw, I'm halfway decent at mechanical stuff....rebuilt a 350 engine, a tranny, and replaced cylinder sleeves and the drive pinion/gear on an old 580B I used to have........Not looking forward to pulling this pump though....older I get the less I wanna do........lol
    z
    Vetech63 likes this.
  15. Vetech63
    Aug 10, 2016
    1,583
    Oklahoma
    Before you pull it make sure TPG gives you some guidelines. You will need to pin the gear before you pull that pump so you don't have a mess later.
  16. thepumpguysc
    Mar 18, 2010
    4,753
    IF you think your getting fuel ON TOP OF the diaphragm..{highly unlikely}
    Just pull the boost line on the pump & start the engine & rev it or run it threw the yard a minute..
    IF its a blown diaphragm, the hole where the hose went will be wet.. & dripping..
