Case 580k hydraulic leak when parked
Discussion in 'Tractor/Loader/Backhoes' started by Northerncase, Jan 14, 2022.
  1. Northerncase
    Northerncase New Member
    Jan 14, 2022
    2
    Ontario
    I am a new owner of a 1990 580k bought it with 6000 hours. My main concern is the hydraulic leak when parked it looks to be leaking somewhere on top of the front differential and then dripping down I think I will need to remove the rad to get a closer look. I’m just looking to see if anyone has had same issue and what I might be looking at for a repair.
  2. alrman
    alrman Senior Member
    Jun 20, 2009
    2,978
    QLD Australia
    Welcome to HEF @Northerncase
    Usually a leak like that, while parked, would indicate a problem with the hydraulic pump suction hose.
    But I have also seen a pumps leak from the input shaft seal, but that would also leak more so while running.
    Hopefully you will spot the issue easily.;)
    Coy Lancaster likes this.
  3. Northerncase
    Jan 14, 2022
    2
    Ontario
    Thank you I will hopefully tackle next week I will post what I find
  4. Steve Favia
    Steve Favia Well-Known Member
    Jan 29, 2019
    96
    Retired local 150 Operating Engineer
    illinois
    Sounds about the spot where my 580k leak turned out to be,mine was the hydraulic cooler in front of the radiator pretty easy fix, soldered up a small pin hole good luck finding your leak.
