yamiacaveman
Hi All,
I have a 580k backhoe and I am looking for a way to get to a grease fitting. Where the hoe connects to the tractor, there are two pins, the top pin has a grease fitting on the bottom and I can easily get to that. The bottom pin looks like it has some type of covering over it with a slot in it. I can't see inside the slot and my grease gun tip will not fit through the slot. Is it a covering of some sort , and if so can I remove it (and How) or is there a special tip I have to use to slip it in and grease the fitting.
Thanks for any help!
yamiacaveman
yamiacaveman
