case 580k backhoe kingpin 4 wheel drive
Tinkerer
Welcome to HEF, Lou !
Quite a bit. Do you have a service manual ?
If not I recommend that you get one because you will be needing it many times.
I can copy and email you the pages showing the procedure if need them immediately.
Bootheal
Jackson, MO
I also have a question if the kingpin you are referring to is the pivot shaft for the front axle.
How do you check for worn bushings & pin on the front axle?
580M
Thank you
Tinkerer
Lou has a 4 wheel drive. #12 and #16 are what his kingpins look like.
Put a jack under the counterweight and slightly raise the front of the tractor. Any looseness can easily be seen in the axle center pin not the king pins.kp.png
Willie B
Mount Tabor VT
Electrician
My 1956 Powerwagon has a similar set up. The manual calls them trunion bearings. I'd say it isn't a big deal to replace, or reshim them. Mine needed seals, and if I recall we replaced wheel bearings at the time, the planetary was leaking.
If I recall correctly, they are tapered, and minor wear can be corrected by removing three bolts top & bottom, and removing shims. It IS something you'll want a manual for.
