ron h
I have a 580e rops model, 1987 ish, One day I went out and turned the key and nothing... No power to gauges and it won't turn over. I cleaned and replaced ground on battery and battery is fully charged. The starter will turn over when jumped from the post to the solenoid. I have the model that has two relays under the instrument panel It has an open spot for a third but I believe thats for cab... I have two relays on order .. Thinking if its not that it might be key switch....Any other Ideas? My wiring diagram shows a circular solenoid, I do not have one and have been all over the machine and can't find one.... I just have a relay set up
Any help appreciated. I have moved the shuttle arm but no luck, with it out of place the gauges should work and they don't... Thanks. Ron
