GregoryJohnston77
Hey guys, so I dropped a valve few months ago, i repaired that got it all back together. Runs great then I noticed latley i been leaking water in my oil. I pulled the valve cover, did a pressure test to check the freeze plugs, they're fine. I pulled the injectors and they looked okay one kinda looked a little milky but not bad infact I cant really tell if it was milky at all, it just looked a little more wet/colored then the others. I pumped it up to 20 psi and it leaks down fast like maybe 10 minutes. I havent pulled the oil pan yet but I'm getting ready too, the engine was rebuilt not long ago, so mentally (lol) I'm trying to rule out the linner or o ring, my question is could it be leaking threw the water pump? When I had the head machined and put it all back together I forgot to re torque the head bolts a second time. I think in the manual it says run it a few hours then re torque them. (Could I have ruined the head gasket maybe?) So I guess my question is other then the liner could it be anything else. It don't over heat, it dont smoke I just dont understand it. After I submit this thread I'm going to pull the pan and check, so I'll get back to y'all but any info is appreciated. Thank you guys so much and stay safe out there, Greg
