Kip in Kansas
I didn’t think to check the relief valve, but I’d think if it was stuck open I wouldn’t have pressure at any time and I have 110psi at idle in reverse. I might give it a look anyways just to rule it out.Did you check the relief valve in the cooler line ?
It isn't stuck open from some kind of crap in it ?
It is still strange that you don't have that oil port on the upper rear of the case.
Here is an image from the service manual showing the oil flow.
Perhaps it may help.View attachment 228544
I do have the #1 port in the upper rear of the case. That’s where it shows to hook up the test gauge and that’s where I’ve got my gauge hooked.
