Pearce Graham
Hello all, new to the forum and looking for insight into this problem. Tractor started loosing power and then shut off. I thought maybe it was out of fuel so bought 10 gallons of diesel and put it in it. still nothing so I took the line off on the bottom of the tank and with the petcock open, no fuel came out. Got my air pig and blew into the bottom of the tank and got fuel flowing again. Took fuel filters off and they were full of rusty watery crap from the tank. Changed filters and bled air off the fuel system. She fired right up and ran better than ever for a few minutes and then shut off again, now it will not start but I have fuel at the injectors and light smoke from the exhaust while trying start it. My question is, could I have gotten trash past the filters and into the pump causing a low pressure condition while still getting fuel to the injectors? Return side glass ball check and spring are fine and the inlet side screen is clean. Tank has been drained and cleaned with all new diesel fuel. If it is just a coincidence that the pump went out at the same time as a fuel supply issue, what are the symptoms of a faulty injection pump? Is there a way to check output pressure of the injection pump? This system utilizes a Stanadyne DBGFCC431-64AJ. There is no lift pump in this system.
