Ryan Fisk
Hello all,
Hoping to hear your thoughts on what could be wrong with my 1974 Case 580B.
I just replaced the transaxle on my 580B because of a bad ring and pinion. Before the swap the backhoe would move forward and backward fine, (with the exception of the rear end issues). The ring had some teeth missing so as you can imagine it would constantly grind when the bad teeth came into contact with the pinion. Anyway after I completed the swap, the machine now has low transmission pressure when I go into reverse. It will barley move at all when in reverse. It goes forward fine with good pressure, also has good pressure in neutral. Although it does not seem to have as much pressure in the forward gear as before. I changed the transmission filter and put in Rotella hydraulic/transmission fluid, the fluid level reads perfect. I didn’t touch anything at all on the shuttle shift unit during the swap. All the I can think of is maybe the shims on the transaxle output shift were not measured correctly (not sure if that would even relate).
Please help and let me know you thoughts.
Thanks!
Thanks!
