:Banghead:Banghead:BangheadI just bought a Case 580B CK backhoe and it has hardly and power in the transmission. I am new to heavy equipment but I know the basics. The machine has a hard time climbing the slightest hill or when pushing into a pile it struggles. The motor doesn't bog down ,it just keep running at the same rpm(maybe a tad bit faster) The trans oil pressure gauuge reads in the green when in gear and clutch is released. When depressed it drops in the red or zero. I Just changed the filter in front of the radiator(torque convertor filter?) and my oil levels are ok. The oil does not appear to be comtaminated. What other thing should I check and or replace? I am also having some brake issuses but I do not believe it is having any effect on the sluggish power. Any suggestions on what else may be causing this?
