Hello. I'm going to try to replace the radiator. In addition to some aftermarket leaks, it has the lower hydr fluid cooler.
Questions:
Radiator is the A39345? That's what I come up with on the electronics part catalogue.
Do I ONLY have to remove the two water hoses, two hydr lines, and the two bolts holding the A35574 radiator support bracket? Then pray?
Are there any aftermarket sources for parts I should avoid? Is $650 for the replacement radiator a reasonable price?
Since I'll have the lower hose off of the block is it okay or advisable to try and flush the engine using that inlet with a water hose?
Thanks.
JBP
Questions:
Thanks.
JBP
