Case 580 Super M planetary disassembly
GManBart
Michigan
Work for the Citizens of the U.S.!
The right front axle started leaking a little bit (very little) recently, so I pulled it all apart so I could replace the balljoint, kingpin, and seals. I noticed there's a bit of play between the swivel housing and the inner half of the planetary hub that shouldn't be there (when I did the same repair on the left side there was zero play).
So, I need to separate the planetary hub from the swivel housing, and thought I'd see if there were any tips or things to be aware of before I get started. As best I can tell there's only an inner bearing, seal, and outer bearing. Am I missing anything? Here's what I'm looking at:
sheepfoot
wilmington nc
It's a little easier with it still mounted to the axle. The seal and inner bearing may stay on the inner hub once the housing comes off or may come off with the housing. I have a large puller that makes it easier. A porta power/ bottle jack in the center and some chain will also pull the hub off. I have seen them almost slide off by hand and seen them be real tight. Seal and bearings are pretty pricey, do the inner seals and bushing/bearing while your there also.
GManBart
Michigan
That makes sense...thanks. I'm definitely doing all the seals and bearings as well as new kingpin and balljoint...might as well.
We have a pretty good puller selection at work, so I'm going to see if there's anything that will fit. If not, I'll try the chain/jack technique. What about reinstalling the bearings...any tips on that?
joe--h
Utah
Good day to all!!
I am a recent member and was wondering how to start a new post pertaining to a 2007 case 580sm
Hope someone is able to help
Ryan
Go back to the forum page and it's just to the right up above, blue box sez post new thread.
