Case 580 LE oils
Discussion in 'Tractor/Loader/Backhoes' started by LRT Caleb, Sep 7, 2022.
  1. LRT Caleb
    LRT Caleb New Member
    Jul 24, 2021
    3
    Self employed field mechanic
    Garvoc
    I have a 1998 Case 580LE 4wd to service and the book specifies Hytran for the trans and MS1210 or TCH for the hydraulics.
    Wondering if it is strictly necessary to run TCH in the hydraulics and if I can use an alternative without causing issues?
    Also, I'm a bit puzzled why the trans doesn't run TCH? I assume it is a Carraro.
  2. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    8,285
    TCH does not have the anti-chatter additives need for clutches and brake linings.
    You could use an TCH alternative brand oil provided it meets the CNH branded specifications.
    LRT Caleb likes this.
  3. alrman
    alrman Senior Member
    Jun 20, 2009
    3,107
    QLD Australia
    There's no problem using 68 hydraulic oil for the hydraulics.
    If the transmission is shuttleshift - yes, use the Hy Trans
    If it is powershift - use ATF III
    The rear axle will use Hy Trans BUT you will need to also use Case Axle Additive (402982A2) with it.
  4. LRT Caleb
    Jul 24, 2021
    3
    Garvoc
    Thanks for that info - much appreciated!
