D26 ..........to me it also sounds like you are leaking internally in that cylinder or it is possible that the piston nut in that cylinder has come loose allowing oil to bypass the piston i think i would eliminate the packing's that jusk mentioned and nut first .........I havent done this one myself but i read where if you start up the machine and you get the hyd oil up to temp and cycle that cylinder and hold the valve that if the piston is leaking internally past the piston the outside of that cylinder will get a lot hotter than one thats not leaking inside....What the heck its worth a shot.....
Mine had a ton of leaks on the valves when i got it and a lot of drifting going on but after rebuilding the cylinders the drifting stopped then i fixed the valves that were leaking...
