Dirttracker18
Hello all,
First post here as I attempt to get my old backhoe operable.
I acquired this machine broken very inexpensively. The owner had a broke the pinion gear and never got around to the big job of changing it. As such it sat for about 10 years. I brought it home and got it into my shop. This has not been a priority project as much as I'd love to be working it. This has basically been on the back burning, something I worked on when I had extra time on my hands.
Fast forward a few years and I finally have changed out the ring and pinion and got the tractor back to one piece!
Now onto the current issue. After sitting for 10 years, the engine will not turn over. The previous owner was using it when the pinion broke and states it was running fine. This is not the first engine I have worked on that after sitting did not want to turn over. Most of the time they have seized rings and that can be broke loose. On a unit like this I'd be happy to get it turned over and then work on getting it running.
The issue is that I cannot seem to find a good place to put pressure on the engine to turn over. The only location I have is through the starter hole, with a prybar, onto the flywheel teeth. This is far from ideal.
Am I missing someplace better? Anyone have any ideas or gone through this before?
Other info:
It is the diesel version
The hydraulic pump is mounted on the front making it difficult to find a location there.
I have been dumping anti seize liquids down the injector holes for some time now.
Open to ideas and hoping someone has dealt with this before. If I cannot find a better solution soon I will be starting a tear down to see inside. I'm really hoping to avoid that.
Thoughts?
Other info:
Thoughts?
