New member here, so I don't think I am allowed to start a new thread, but my question is related to this thread. I have a "new to me" 590 SL. When it showed up on the truck, it had a hyd oil leak under the front axle. After looking at it, there was only one bolt in the pump coupling and one that had backed out. Also, the one bolt had several washers between the coupling and the pulley. I found the rest of the bolts in the compartment by the steering wheel. I put all the bolts back in (without the washer/shims) and when I restarted the machine I had no hydraulics. Sure enough, the coupling was spinning and the pump shaft was not. I pulled the bolts back out and put the same amount of washers between the coupling and the pulley and I guess there was enough spline engagement to turn the pump. This also stopped the hydraulic leak and I have been doing very minimal tasks with the hoe. Seems it has full power and speed. I am figuring a new pump is in order, but want to get the root of the problem fixed first so I don't trash the new pump shaft. Reading through these forums, I learned to check the front mounts. One side is good, the other side has the rubber, but no bolt. I'll have to pick up the metric bolt and replace that. My real question is, is that all there is to it? The 4 bolts between the mount and the block are all tight. Any reason to take these out and inspect the dowel pins? The work looks easy enough to do (this site has been fantastic for a newbie like me). I already have two new rubber mounts for the front and plan to change those out as well.
