Cariboo4x4
I been experimenting with setting my carrier bearing preload. So far I have installed new carrier housings with new races, shims, and new bearings and thrust washers on my side gears. I adjusted the side gears to center wheel pinions backlash on the workbench. My service manual stated how to use the dial gauge to measure correct backlash. I installed new metal thrust washers since I was advised to avoid reusing the old style fiber thrust washers.
I won't install my seals and o-rings until final assembly. The service manual spec is 3-8 ft lbs preload. So I have it preloaded up to 5 ft. lbs rolling torque. The ring gear is stiff to turn by hand. Is it normal that you can't turn ring gear if you prevent one side gear from turning? I have everything lubed.
